my version is Hypermesh 2024.1. In preference I saw the default units was
MMKS (mm kg N s). But when I create a material, in density the default value was 7.85e-09. It seems system still use tone/mm^3 for density. So which one is right? Should I change the value to 7.85e-06? By the way, I seem to remember old version use mm/ton/N/s. So which version it changed?
