Ive been trying to find a way to create surface mesh of the 3D mesh ive done.
I did find this very old discussion on it but cannot use it in the 2023 Hypermesh version I am currently using -
Kindly help me though this
Regards, Adi
Hello Adi, This functionality is still available via Validate/Faces.
Please keep in mind you need to rename the ^faces component name. Component starting with ^ will not be exported to the solver deck. Best regards, Gunter
Thank you @Gunter. Did want to ask, does the ^ not import to the solver deck even if I make a Component and name it ^component 1?
Hello Adi, Thanks for the reply. Any component whose name begins with ^ will not be exported to the solverdeck. Best regards, Gunter
