Altair RISE
Nominate Yourself Now!
Hyperworks v14 student license error
User: "Altair Forum User"
Updated by Altair Forum User
Hello, I get the following error when I try to run the hyperworks software. I have placed the license file in the required file directory. However, I still get the error even though it is there.
Altair License Manager: License error
Feature: GlobalZoneAM
Error Code: 9
Error Description:
[LOCAL] C:/Program Files/Altair/14.0-edu/security/altair_lic.dat - (Err: 9) Feature not found
Feature: HyperMesh
Error Code: 9
Error Description:
License Path: C:/Program Files/Altair/14.0-edu/security/altair_lic.dat
1 - 3 of 31
    OP
    Hi Warren,
    Can you check whether the Ethernet ID of your machine matches with the Ethernet ID used for license?
    If both Ethernet IDs are same, Use windows folder options > unhide known extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat,
    Also, have a look at below post:
    OP
    No, they don't match. So I copied my ethernet ID and paste it over the other one and it still doesn't work.
    OP
    Hi Warren,
    Copying and pasting Ethernet ID to license file doesn't help.
    You need to apply for a new license using the correct Ethernet ID.
