Tried using Fashion_MINST dataset for CNN model. I am getting an error "Your connection is producing wrong type of data. Try changing the starting point of the connection". When I clicked the yellow exclamation symbol in "Add Convolution Layer" it gives the following message "Expected LayerListIOObject" but received ExampleSet". I used Fashion_MINST dataset and wanted to work on CNN model. I am attaching the .rmp file. Please let me know where is my issue. I was told that I need to transform the tabular data into image format before passing it to the "Add Convolution Layer" operator but I do not know how to go about doing this transformation to image format in the sense what RapidMiner Operator should I use for producing that transformation into image format. I have looked at Youtube videos and most of the examples were code based and not rapidminer tool. Hence need help. I could not attach the Fashion_MINST data set CSV or Excel file in this page but please take it from Kaggle or unstructured data topic.
Note- I was not able to attach .rmp file hence converted to.txt you can download it and re-convert it to .rmp and let me know the resolution
