I asked for a student license and everything went smoothly. However, after installation, Hyperworks cannot run due to license problem (error 9). I guess that, although the host id I communicated was right, the existence of several ethernet ports (none called 'Ethernet adapter local area connection') can be the issue. The ethernet host ID was 001517E8F289 and this is what is read from ipconfig /all command. How the issue can be fixed?
ipconfig /all
Configurazione IP di Windows
Nome host . . . . . . . . . . . . . . : comech3
Suffisso DNS primario . . . . . . . . :
Tipo nodo . . . . . . . . . . . . . . : Ibrido
Routing IP abilitato. . . . . . . . . : No
Proxy WINS abilitato . . . . . . . . : No
Scheda Ethernet Connessione alla rete locale (LAN) interna:
Suffisso DNS specifico per connessione:
Descrizione . . . . . . . . . . . . . : Intel® 82575EB Gigabit Network Connection #2
Indirizzo fisico. . . . . . . . . . . : 00-15-17-E8-F2-89
DHCP abilitato. . . . . . . . . . . . : No
Configurazione automatica abilitata : Sì
Indirizzo IPv6 locale rispetto al collegamento . : fe80::e1f5:3933:2f69:80e5%13(Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 192.168.137.1(Preferenziale)
Subnet mask . . . . . . . . . . . . . : 255.255.255.0
Gateway predefinito . . . . . . . . . :
IAID DHCPv6 . . . . . . . . . . . : 301995287
DUID Client DHCPv6. . . . . . . . : 00-01-00-01-1C-71-27-8E-00-15-17-E8-F2-88
Server DNS . . . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS su TCP/IP . . . . . . . . . . : Attivato
Scheda Ethernet Connessione alla rete locale (LAN) esterna:
Indirizzo fisico. . . . . . . . . . . : 00-15-17-E8-F2-88
Indirizzo IPv6 locale rispetto al collegamento . : fe80::813d:4fae:3af4:e909%11(Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 130.192.29.10(Preferenziale)
Gateway predefinito . . . . . . . . . : 130.192.29.17
IAID DHCPv6 . . . . . . . . . . . : 234886423
Server DNS . . . . . . . . . . . . . : 130.192.3.24
130.192.3.21
Scheda Ethernet VMware Network Adapter VMnet1:
Descrizione . . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
Indirizzo fisico. . . . . . . . . . . : 00-50-56-C0-00-01
Indirizzo IPv6 locale rispetto al collegamento . : fe80::25ce:1d41:fb76:26b%15(Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 192.168.171.1(Preferenziale)
IAID DHCPv6 . . . . . . . . . . . : 385896534
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Scheda Ethernet VMware Network Adapter VMnet8:
Descrizione . . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
Indirizzo fisico. . . . . . . . . . . : 00-50-56-C0-00-08
Indirizzo IPv6 locale rispetto al collegamento . : fe80::9173:8719:b8a2:1a98%17(Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 192.168.150.1(Preferenziale)
IAID DHCPv6 . . . . . . . . . . . : 419450966
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Scheda Tunnel isatap.{09779D96-6946-4C9E-B0C4-D1B22210ACE5}:
Stato supporto. . . . . . . . . . . . : Supporto disconnesso
Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter
Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0
Scheda Tunnel isatap.{952F608E-0E81-4957-81E8-D2CF42D8E90D}:
Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Scheda Tunnel 6TO4 Adapter:
Descrizione . . . . . . . . . . . . . : Scheda Microsoft 6to4
Indirizzo IPv6 . . . . . . . . . . . . . . . . . : 2002:82c0:1d0a::82c0:1d0a(Preferenziale)
130.192.3.21
NetBIOS su TCP/IP . . . . . . . . . . : Disattivato
Scheda Tunnel isatap.{54CF6C6A-BC11-4199-87EF-DE44A5077F43}:
Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Scheda Tunnel isatap.{9C3883A3-C3C3-46DD-80CA-731B8CB2F899}:
Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter #4
