Files required to run newFASANT 2025 have been removed from the standard Feko 2025 installation.
Should you want to expand your Feko 2025 installation to support creating, opening and running newFASANT, please follow these steps:
- Install Feko 2025 on your machine following the standard installation process. Note the installation path (FEKO_HOME) used for the installation.
 - Download the newFASANT archive for your operating system below and extract it into a convenient temporary location on your machine (contact Altair Support for information on how to download the archives)
 - Copy the files extracted from the archive in point 2 into the Feko installation (FEKO_HOME) location. Note that this will require the necessary permissions for the user copying the files.
newFASANT should now be added to your Feko installation and can be launched from the Feko Launcher (GUI) or command prompt as per the Feko user guides.
