How to use tcl command *createmark with option "contains value"
User: "IsabellaR"
Altair Community Member
I am trying to select components via tcl whose name contains the string "DIN". I.e. I want to select all components with the following names: "DIN123", "something.1\DIN891", "this-is-a-component-DIN-2010" and so on.
I tried the following line:
*createmark comps 1 "contains value" name "DIN" 1
But when checking if any components were selected by:
hm_getmark comps 1
I do not get any ids, so aparently my selection was not successful.
What did I do wrong?
Thanks!
1 - 1 of 11
    User: "Adriano_Koga"
    Accepted Answer
    you should use some wild card (*).
    example:
    set max_thick [hm_getfloat "Thickness Limit:" "Definie Thickness Limit for detection:"]
    #selects all components starting with 21
    createmark comps 2 "contains value" name 21*
    set bolts_list [hm_getmark comps 2]
    *clearmark comps 2
