The HM2024 model I'm working with has fasteners in different orientations. The analysis systems for the nodes attached to these fasteners have been updated to align with geometry. When exporting the FBD loads tables for all 14 load cases the first load case recognizes the correct CSYS but the remainder cases the loads use the global CSYS.
As a fix - exporting the loads one case at a time works but it would be helpful if all load cases used the analysis systems.
Am I doing something wrong that changes the FBD CSYS's.
Any insight would be greatly appreciated.
Thanks!
