code coverage causes to crash
User: "Deniz Güzel"
New Altair Community Member
Updated by Jocelyn
Working dsim verification environment crashes when I gave the flag called "-code-cov a". Before giving that coverage flag it compiles and simulates perfectly. The crash comes from CGModule.cpp line 354. There is a assert statement that fails and crashes program with flag "=F:[Crash]". The verification environment includes nothing special or too complicated. It includes standard UVM components and trans_items plus RAL model with frontdoor and backdoor access to check how dsim works with RAL model. Design is SystemVerilog. Detailed log file can be found inside attachments. Configuration of project can bee from dpf file which is given below :
# Note: The contents of this file are automatically generated.
# Any changes made by hand may be overwritten.
version: '0.2'
work_dir: .
design_root_dir: .
simulations:
  - name: run_regTest
    options: >-
      -top uvc.tb_top -L dut -L uvc +acc+b -waves waves.mxd -uvm 1.2
      +UVM_NO_RELNOTES -sv_seed 365 -code-cov a
source_files:
  - language: verilog
    path: ./design.sv
    library_name: dut
    options: '-timescale 1ns/10ps'
  - language: verilog
    path: ./flist
    library_name: uvc
    options: '-uvm 1.2 +incdir+dir[+./.]'
    file_list: relative-to-file
library_search_paths:
  - $STD_LIBS\ieee93
I am using Windows 11 and Dsim version is 20240422.0.0
1 - 1 of 11
    User: "d3jones"
    Accepted Answer
    This is a known issue. The current release will crash if you attempt to instrument the UVM library for code coverage.
    Assuming you don't want to cover your testbench, a workaround is to instrument the RTL only. This can be done with -code-cov a -code-cov-scope-specs <file>. Example of a coverage specs file:
    # Example code coverage specs: enable block coverage on DUT only
    path tb.dut +b
