I kept getting errors when I tried to run the solver for examples that were given.
Like the title says, I believe that I inputted an incorrect ethernet physical address when I enrolled for the student license. (When searched for my ethernet address from the CMD line, I had multiple ethernet addresses; I chose a disconnected one.)
How do I fix this?
If you had given a wrong Ethernet ID, then re-apply for license with correct Ethernet ID.
If you are confused choosing the Ethernet ID, you can post the Ipconfig/all output image here and we can help you
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
