HyperStudy EDU License Error
Hey there!
I'm having a bit of licensing trouble with a HyperStudy model. I'm able to run this deck on Compute Console but I can't get it to run when I import it on HyperStudy either as a an OptiStruct model or Parametrized File.
Parametrized file error:
OptiStruct model error:
Everything seems to be ok with the license
Also, I can't use the Export HyperMesh to HyperStudy functionality..
Is HSt EDU limited to the example problems? Anyhow, thanks for you time.
Hey Adriano,
I'm not sure if that's the case, since I'm able to run the examples files from HyperStudy's start page:
In any case, I was trying to run a DoE for a laminate plate, to minimize max displacement. I had created parameters for plies thickness (same thickness for all) and for individual orientations.
But then I found out about OptiStruct's Three Phase Optimization of Composite Structures. Do you happen to have a shareable example/tutorial about this?
Thanks a lot!
im not sure if this applies to HyperStudym, but apparently the only way of running models in the Student edition is through the Compute Console. Maybe HyperStudy is considered as 'command line'?
https://web.altair.com/altair-student-edition
