Suppose in an output, voltage and current wave comes simultaneously. but my question is i just want to make current wave form to be delayed by a certain time so that desired waveform can be obtained.
Hi Jyotiprakash,
Do you want to introduce delay in current? or only for simview results?
Can you elaborate your question?
Thank you,
Vishwanatha Siddhartha
Hi there,
I'm not sure about your application, circuit and load but, you can achieve a phase delay between the voltage and the current by adding an inductor and a resistor in series. Change the values of the inductor and the resistor accordingly until you get the phase you are looking for.
On the other hand, if you want to achieve a specific "wave profile" you might need to dig deeper into something like a Fourier transformation of the wave profile you want to achieve.
Hope this comment helps!
