I'm doing an FSI simulation of a pitching and plunging NACA 0012 and I'm trying to model the structure.
In the image below, you can see the airfoil , with an initial pitch of 5deg, which has 2 DoF: rotation and vertical movement. These two DoF have been represented with 2 springs (PBUSH), a vertical and a torsional one.
The problem is that the equilibrium position of the torsional spring is 0deg. So the starting point (5deg) should be preloaded.
How can I do this in Optistruct?
Thank you for your help,
Alice
