Hi I am trying to Mesh a Air blower model in Simlab. After I plugged the fluid regioand MRF Zone, I done the Surface meshing. Then I am trying to do cfd meshing.
In CFD meshing, I select the the Fluid Body as plugged fluid volume and mrf zone, then Ignore BL surface as Inlet, outlet and MRF zone surfaces.
If I click ok, It  got meshed, But the 3d mesh for Fluid volume and MRF zone was not come like separate 3d mesh for each part, It gets combined and make it into one part.
How to clear this issue in simlab cfd meshing?
Thanks & Regards,
Sivaprakash V.
