License Error while Radioss Run
Updated by Altair Forum User
I have encountered many troubles using the Radios Solver Run Manager because while installing (Did it 5 or 6 times, also an older version) there were no shortcuts created. So after all I created my own shortcut using an installation on another PC as template. No I can start it but everytime I try to use the Radios Hyperworks Solver Run Manager it stopps immediately with the error message in the attached image.
Other parts of HyperWorks like HyperCrash do not show license errors and work fine.
Thank You in advance for your Help,
Alfi
Hello.
I have the same error
Did you solve it??
Thank you
