Dear FLUX community,
I am building a model which accounts for every strand of conductor in bundle (Please see the diagram attached). This model has real end-winding connection and it has passed all the checks before solving. Another thing maybe helpful is that this model does not use aided mesh and all the mesh information is defined by user. As for the relaxation, only one null relaxation face is assigned to the baseline face of round conductors to ensure consistent meshing (The model is built in 2D and all the other corresponding conductor faces/volumes are related to each other).
This model seems to be good to solve, but the solving process stops in the middle of scenario with this warning that I copied from report file:
[87977|1664036161591|498|INFO ][ErrorManager|ErrorManager.createFortranException] : Type: 500 Message: INV => Problem with Hyper-Matrix DETPG
[87978|1664036161592|498|INFO ][Fortran.Error|ErrorManager.createFortranException] : Type: 500 Message: INV => Problem with Hyper-Matrix DETPG
[87979|1664036161606|500|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: INV => Singular matrix for volume element 236089
Non managed error which has stopped solving process
[87981|1664036166424|30|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: Non managed error which has stopped solving process
[87982|1664036166425|30|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: PBEPAV_3 => Error 49, no treated error type
[87983|1664036166425|30|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: PBCEVL_4 => failed
And the volume element 236089 mentioned in report file is one of the end-winding regions and at first I thought something is wrong with geometry and I actually have built another similar model but it gives same warning message. I think the problem is in the setting of relaxation lines/faces/volumes or maybe shadows? I have tried many other methods that I can think of many times and it all didn't work. Can someone help me with this please! I am ok with sharing this model.
