Hello Team kindly let me know where is the below shown tools in Hypermesh 2024.1 Thanks and Regards Sandeep k Mahato
Hello Sandeep,
You can use the Tool Finder from the online help to view a list of deprecated panels and their newer, equivalent workflows ⇒ https://help.altair.com/hwdesktop/hwx/topics/panels/tool_finder_r.htm
The extract parametric nodes on surf is available from the 'Extract Points and Nodes' ribbon.
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/geometry/points_nodes_extract_t.htm
The creation of midsurface from a surfaces pair can be handled by the Automatic Midsurfaces Extract tool.
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/geometry/midsurface_extract_t.htm
The review thickness from midsurf tool is deprecated and replaced by the 'Apply Thickness to Midsurface' tool ⇒ This method retrieves the thickness value directly from the volume (solid, surface or element). This way, no need to keep the midsurf or to check the thickness of the midsurf. If you have a 2D mesh and the initial solid geometry, you can use them.
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/geometry/midsurface_thickness_apply_t.htm
Regards, Fred.
