In fluxmotor I had entered an excel with BH values for the lamination materials. There, flux motor calculated a fitting curve for the BH curve. How can I re-enter the BH values in fluxskew without taking a fitting curve?
kind regards
Hello Kehollev, Thanks for writing to us.
You can create a material with Spline type, where you can enter the values of B-H Curve. Please refer to the below document to understand about Soft Magnetic Material of Spline type. https://help.altair.com/flux/Flux/Help/english/UserGuide/English/topics/MateriauDouxIsotropeAnisotropeCourbeDeSaturationSpline.htm?hl=isotropic%2Canisotropic%2Csoft%2Cmagnetic%2Cspline%2Csaturation%2Ccurve
Best Regards, Charishma
Yes indeed, but I have wanted to use material manager before, but it does not want to open when I press it in the supervisor in altairflux? So I want to adjust my materials that I imported with my motor design from fluxmotor in fluxskew. This is not possible in fluxskew, so I tried it via the material manager. In fluxmotor I could not use spline type.
