Dear Flux community,
I am now building a 3D model by extruding the 2D geometry with associated mesh generator. The aided mesh is deactivated and all the mesh information is defined and assigned to the geometry manually in 2D to avoid problems in 3D modelling. My problem is that, the mesh for round conductor in 2D is OK (the mesh is uniform), but when I extrude the geometry in 3D, the mesh of the round conductor becomes un-uniform, which is not acceptable.
The difference between 2D mesh and 3D mesh is attached, the diagrams only illustrate mesh of X-Y plane (Z direction has structured mesh so it is not shown here). I can also attach this flux file if necessary. Thanks for your help.
