I have created a simple model of 4 connected wires, and replaced one of the wires with a cylinder of the same radius. All the 4 corners have the same coordinates.
Is there a way to find out if the objects are connected by the mesh without starting a simulation and checking the currents?
Is there a way to find at which position the break in connectivity occurs?
Is there a way to ensure connectivity between 2 lines or a line and a solid?
