Altair RISE
Nominate Yourself Now!
Help!!! Some unusual FLUX 3D ERROR message
User: "Yangyu Sun"
Altair Community Member
Updated by Yangyu Sun
Dear Flux community,
I am modelling a FLUX 3D model in steady state AC magnetic 3D context. The model uses rectangular bar conductor and it has real end-winding connection and a coil conductor is used to represent the winding region in the electrical circuit with input and output defined properly (see the diagram attached). However, when I check the physics before solving, an error saying 'MECDX3_2 => Singular jacobian for element 94095, MECDX3_2 => Unable to compute jacobian' confuses me. This particular volume element is the layer between the infinite box and the actual machine. At first I think it is the coarse mesh of infinite box, so I change it to a very fine mesh, this error is still there. I have also deactivated aided mesh and manually setting the mesh of model but this method also won't help. Does anyone know what has gone wrong? I have been trying to fix this in the past few days but failed and it's really killing me. Thanks for your help.
Yangyu
1 - 5 of 51
    User: "fzidat"
    Updated by fzidat
    Hello Yangyu;
    If you can share your Flux project i can have a look on it. If it is confidential, then use your Professional access to the support.
    Regards
    User: "Yangyu Sun"
    OP
    Hello Yangyu;
    Regards
    Hey Farid, can you please tell me how to use the 'professional access to the support' feature?
    User: "Yangyu Sun"
    OP
    Hello Yangyu;
    Regards
    I am now building a simplified but representative model, I am hoping this model gives same error and if it does, I will send it to you.
    User: "fzidat"
    Updated by fzidat
    Hello Yangyu;
    Instead of 'ask a question' use 'create a case'
    Regards
    User: "Yangyu Sun"
    OP
    Hello Yangyu;
    Regards
    OK. Thanks a lot!
