I wonder if it is possible to apply an external or remote load in a static linear analysis using SimLab?
Regards.
Can you give us more details? If I understand correctly, you have your main assembly and it should be connected to other bodies not modeled where the force is applied, right? You can create a node where the force should be applied:
And the create an RBE between the nodes "connected" and the one you created in space and then apply the force there:
Hope this helps.
Kind regards,
Marc Steiger
