Is there a simple way to convert a PCOMP/PCOMPG composite model into PCOMPP?
Which allows me to easily changing the stacking sequences?
Best,
Jerome.
Hello @jerometeoh ,
did you look at this script:
Michael
hello @jerometeoh ,
“WOUND” is used to represent the filament winding process, where typical coverage of a “ply” can have all of spatially varying thickness and orientation on a spatially varying number of layers.
WOUND today is usually populated from external manufacturing software. It’s just a datastructure though, and if your company has a manufacturing process from which they want to pass data which is spatially varying (including number of layers per “ply”), it can be populated via script.
Hope that helps,
Michael,
Thank you for this.
I cannot find the script in my pc.
But I think I found out that as I am using HyperMesh 2023.1.
Looks like I can just execute 'absorb' within the composite browser, it should yield the same result?
did you download the script available as attachment in th elink I shared with you?
Best Regards,
Hi @Michael Herve_21439 ,
I just found the script, it is useful thank you! I like how it executing it one-by-one.
I was trying to use this to convert PCOMP to PCOMPP for some filiment winding pressure vessel application. I am wondering if you ever do that? Also, how do people typically use 'wound' ply type?
Very thank you for the script!!
@Michael Herve_21439 thank you for the clarification!!
