i am using HyperMesh 2024.
I already know that Ctrl+Q is the shortcut for "Show IDs," and I have confirmed this in the shortcut settings. However, when I select a few nodes and press Ctrl+Q, it doesn't work. The "Show IDs" function only activates after I right-click once and then press Ctrl+Q.
Is this a bug? If so, it should be fixed.
