With the attached model, when selecting from bottom right to top left, the software just disappears. Not running in Task Manager, no error messages, it just blinks out and I see my desktop.
Hi @PBerry,
I'm sorry you are having trouble with your Inspire installation. Unfortunately, when I open the supplied model and select the part, I have no issues. Please see the attached GIF below.
Please try closing other applications that may be using high amounts of memory. Also, please make sure you have updated your graphics drivers. Does you desktop/laptop meet minimum requirements for using Inspire?
Hope this helps!
Adam Reid
Thanks for the reply Adam.
I have 1 TB RAM, 24GB SSD remaining (no HDD), and two CPUs. However my NVIDIA only has 2 GB dedicated. The spec for Inspire I found only said a dedicated graphics card.
Now that I've seen your GIF, there is something else. The software doesn't close 100% of the time. When it doesn't, as soon as I start dragging the selection box, the model disappears. When I'm done dragging, it reappears, and it is selected. Not enough graphics memory maybe?
It appears that my video memory is too low per this document:
https://help.altair.com/inspire/en_us/topics/shared/unity_basics/system_requirements_st_r.htm
