Hello, is there a way to make a CDF (Cumulative Distribution plot) plot in EDEM? I want to make my CDF plot based on particle diameter. Is there a functionality that I can do this with?
You can export the particle diameter results from the EDEM Analyst (File > Export > Results Data) which if you choose the 'standard' export this gives you the diameter of each particle at the given time-step, which you could then convert into a CDF plot.
Or consider using EDEMpy to create a custom analysis :
Regards
Stephen
Thank you!
