I want to do the parametric sweep for my feed (Xp) is the variable name here, I tried to do a parametric sweep of my variable Xp but my pc shows this "S batch" page, Please help me with how can I do ? parametric sweep in this "Xp" variable in my model? I am attaching here my model , please fix the problem o that I can run a parametric sweep in it. thanks. I set number of samples 93 in the parametric sweep option, so 93 .cfx and .fek file is created, how can I check my results should I have to run all 93.cfx files individually?
Hi @sswh2,
Please remove the parentheses from your *.cfx name. This is a special character that is messing up with the run command of the parameter sweep models.
Best Regards,
Zeina
@Zeina thanks! will do that.
