How to Install Managed Licences
GTDIT
GTDIT Altair Community Member
Hello Team,
Need Assistance on installation of the managed-AU license for AU Mechanical Engineer v2024 as well as AU Mechanical Engineer v2024 from 2024-12-23 to 2025-01-22.
I am not able to Understand what the process, I am not able to get a downloadable file.
I have attached the screenshot of the Managed Licences File Dashboard.
Kindly guide me for the issue should I have installed Licences manually or this is Cloud based Licences, If any procedure let me Know.
  • Adriano_Koga
    Adriano_Koga
    Managed licenses are also known as cloud based licenses, meaning they won't be installed locally (on premises).
    on the user side, 2 things are necessary:
    • having the software installed
    • being registered correctly in the AltairOne portal, and use the same credentials to authorize the use of the software, once you launch some application
    More info can be found here.
    OBS.: some extra firewall adjustements might be needed depending on the restrictions, as the license system needs to access a few external sites.
    https://help.altair.com/hwsolvers/altair_help/topics/getting_started/licensing_hosted_hwu_r.htm
