I need to represent a Wire damper in 3 axis,
In the attached you will find the data for the 3d damper,
I tried to perform this with PBUSH & CBUSH
I'm getting Error 99
Hope for your help
Edit the CID field as 0 and rerun. This should work.
Thanks…
Thank you, Great, the sample working,
how do i represent this damper to 3 axis, there tension and compression in the same direction,
and there is rolling in the auther direction,
You can define the stiffness values in K1 to K6 fields.
Yes, I did sample of my problem,
Can you please check why I do not get the damper affect, meybe the kn_line
FYI
If the SPCD is at the SPC node all the system is moving at the hyperview, for the screen.
