Hello everyone,
Currently, I am using the simcoder function to generate control signals. I first convert the voltage value that needs to be detected in the hardware circuit into digital data through the ADC converter, and then send it to the Simplified C block for processing. In this step, UE1 is the same as the original waveform(V14). The shapes are the same, as shown in the figure.
However, when I want to take the next step and send it to F28335 1ph-PWM, my ue1 waveform is not the same as the original waveform, as shown in the figure.
