Hi, I have this error when running my analysis.
*** ERROR # 941 ***
NON-CONVERGENT NONLINEAR ITERATIONS FOR SUBCASE 1
I tried to adjust the NLPARM parameters: NINC to 30, DT to 0.02, Maxiter to 20, to solve this problem, but it's not helping. The analysis failed at 51% load step.
I applied a 10mm displacement to my model, However, if I change the displacement to 5mm or 20mm, both models work and converge. The model just won't converge when 10mm displacement is applied.
Does anyone know how to solve this problem? Appreciate any help and thank you!
