Hi Everyone,
I have been trying to implement the Bonded-Particle contact model (v3.5.0) API provided by EDEM (from its previous EDEMSimulation forums), then it works fine. At the same time, I also tried to establish a coupling interface between edem2023 and fluent2022r1, and succeeded. When I tried to use the bead chain model created using the (v3.5.0)API and the simple flow field established by fluent for two-way coupling, the residual error was too large, as shown in the figure below.In contrast, when I simply use the built-in Bonding V2 model against the same parameters as for API, then it works fine.
Any suggestions, what could be the potential issue with that?
Thank you.
Best regards,
Bai
