Hi all, curious if I'm running into a common modeling mistake. I have a 2D polyline road profile of a set of bumps that I need to run on with my 2 wheeler model with MF6.2 tires in MotionView 2024.1. The model runs fine on a flat road with tire USE_MODE set to 1XX or with a FIALA tire with 3D_Enveloping enabled.
Referencing the below USE_MODE information within the tire model I attempted running with USE_MODE 414 for 2D road contact and 514 for 3D road contact, but both crash the MotionView session.
USE_MODE 414 produces an error stating "The Contact Method in ISWITCH (XXBXX) does not support a value of 4" which doesn't make sense from the MF documentation
USE_MODE 514 produces an error stating "SALT cannot connect to server (-10078) which appears to be a licensing issue, but I am not trying to run SWIFT rigid ring dynamics, so I'm confused about the license error.
