Format in template
I want to create a macro with template inside to process a large number of entities.
My output format is similar to the picture below.
I know that it is possible to use field() command to write data to ASCII file.
However, I don't know how to write it in the same format in the picture with negative, positive number and exactly 6 number after comma.
Could anyone help me with this, Thanks
I don't know how to control exactly 6 number after comma within a output template yet.
But if this's your indispensable requirement, you can write directly in TCL script.
How about 'large number of entities'? 100k? 1000k? 10000k?
0 -
Yes, to control format of data you should use tcl
example set fx [format %10.6f $x]
for template, you can use *realprecision(6) to control 6digits after dot of reals, and to print them out even if they are zero, using *compressreal(0)
