where can i find abaqus-simlab-edem coupling tutorial?
We don't have an Abaqus coupling with EDEM, you can export EDEM data to different FEA packages but nothing specific for Abaqus:
https://community.altair.com/csm?id=kb_article_view&sysparm_article=KB0037368
Regards
Stephen
Hi QinHe,
In addition to Stephen comments, we don't have any tutorial explaining the simulation steps using EDEM-Abaqus, However Stephen Cole shared the link of EDEM-Hyper mesh where the detailed steps are explained.
If you hypermesh map the forces in hypermesh a, create the load step and export the .inp file for solving the job.
if there is no hypermesh and if you're using Abaqus CAE the force mapping is little time consuming.
From EDEM export the nodal coordinates vs force and check the node numbers related to the co-ordinates and update the co-ordinate position vs force data to node number vs force and solve the job.
Hope this Helps.
Thanks,
Prasad A
