Hello, I am currently testing the co-simulation of MotionSolve, Twin Activate and EDEM using the example of an excavator (with version 2024.1):
Unfortunately, I am having problems visualizing the results in HyperView. The program does not have its own system of units, but uses the sizes of the individual models. The MKS model was created in (mm), but EDEM only exports the results in the SI system (m). Even if the unit is changed to (mm), as described in the instructions, the results in HyperView are loaded in (m).
The approach of converting the MKS to (m) fails, as the program does not convert the sizes, but simply replaces them, i.e. 1m = 1mm, so that the entire model with the distances is no longer correct. These could be changed manually using the data summary, but the CAD data and the control are no longer correct.
Is there a simple solution that I do not yet know, i.e. either exporting the EDEM results in (mm) or scaling the model by a factor in MotionView. Based on the images in the instructions, it should work somehow.
In the CSV export for Hypermesh, you can choose between SI base units and EDEM special units, but then I only have the forces, but not the animation of the particles. Would be similar for the whole simulation.
