I want to check the input impedance(Z11) of my conformal antenna, how can I get the result Z11? Which options should I select in FEKO 2023.1?
If you want to check the input impedance, you can plot your Source data in POSTFEKO. On the right-hand window, you can change the parameter being analyzed to Impedance.
Does this help with your question?
Respectfully,
Evan Urban
@Evan_Urban sir thanks! it helps.
