I’m having an issue generating a mesh in HyperMesh on a part shaped like a tube. The mesh generates correctly on most of the model’s surfaces, but for this tube, I get the message: surfaces are not mappable. Has anyone encountered a similar problem? What steps can I take to resolve this? Should I change the meshing method or modify the geometry?
Thanks in advance for your help!
