Background:
A dump truck is a vehicle used to transport bulk materials, such as dirt, gravel, demolition waste, or coal. Dump trucks are used in a variety of industries for material handling, including construction, mining and quarrying
A dump truck has an open-box bed that tilts or opens at the rear for unloading. Hydraulic rams lift the front of the truck to deposit the material on the ground
Problem Statement:
Dump trucks design and manufacture faces a wide variety of challenges, majorly Tipping, Spillage, Stability, and un-balanced loads caused by offset Centre of Gravity of the load.
It is very expensive, and time consuming to perform physical trials and address the challenges by the OEM’s.
The Multi-Physics (EDEM-OS, 2-way coupled) simulation address most of the challenges experienced by OEM’s because of
- Realistic structural analysis based on material loads EDEM bulk material data
 - Optimize equipment design based on interaction with bulk material
 - Simulate advanced and complex scenarios
 - Reduced need for testing & physical prototyping
 - Greater insight into equipment performance
In this demonstration example the EDEM-OS-2Way Co-Simulation, is used to understand the
- Bulk Material Loading and Unloading
 - Truck body and Tail gate strength
Key Points to be Noted
- The CAD model chosen in the simulation is a representative model that has been simplified for the purposes of this demonstration case
 - Only truck body is chosen for the simulation, all other parts are ignored as they don’t experience any material loads
 - Linear steel material is assigned to brackets, chassis frame and truck body
Prerequisites
EDEM-OS 2-way supports the software version specified below or later versions
- EDEM – 2024
 - OptiStruct – 2024
 - SimLab – 2024
Dump Truck Loading and Unloading: EDEM Simulation Setup
- Define the bulk material properties
 - Define the Particle to Particle and Particle to geometry Interactions
 - Define the particle shape, size and its distribution
 - Import the factory and truck body .stl file using CAD unit as “Meter”
 - Move the factory to required position using transform option
 - Define a factory, to create a bulk material of 7000 kg with a target mass of 5000 kg/s and a velocity of Z= -2 m/s
 - Define the simulation setup such as
- Raleigh Time Step = 20 %
 - Simulation time = 5 sec
 - GPU solver with CPU’s=6
 - Run the Simulation
 - Export the Simulation Deck at time step = 0 sec
 - Open the Exported simulation deck
 - Delete the truck body and factory
 - Update the environment
 - Switch on the coupling server
Dump Truck Loading and Unloading: OS Simulation Setup
- Import the given .fem file and the fem file consists of
- 2D mesh of Dump Truck body
 - 2D mesh of Tailgate
 - A portion of 2D mesh of Chassis frame
 - 1D elements such as Rbe2 elements
 - Select all bodies to define solution as Explicit Dynamics
 - Define settings such as
- Solver Settings
 - Result Request
 - Format and Execute Option
 - Define Joints between Tail gate and Truck body
 - Define Joints between Truck body bracket and Chassis
 - Define Contact between Truck body and Tail gate
 - Create Coupled Solution
 - Define Coupled time step
OS Simulation Setup
Simulation Results
To Know more about Dump Truck one-way coupling please refer below link
To simplify the Dump Truck EDEM-OS, 2-Way Coupled learning, the input files and simulation deck are attached below
OS Input File:
STL File:
EDEM Simulation Setup:
SimLab Simulation Setup:
If you are looking for further information on EDEM or other Altair products we have plenty more on Altair Community:
