hi,
I am trying to recover MBD result for Fatigue analysis.
For now, I could recover MBD result for Transient Analysis but still unable to use these result for Fatigue Analysis.
I used EL2PROP to assign the property to the set elements in flexible body h3d file.
Besides the assigned data from .h3d file and .mrf file, the model only contains load collectors, materials, properties and loadsteps enough for the analysis.
However, the file still could not be run and returned the error as in the picture below.
No elements and nodes should not be included in the recovery run so I could not create element sets.
Attached is the FEM file. Appreciate your help
