I want to show material parameters in comments window when run Radioss file to track the material information.
Is there any ways to do that.
Thank you!
Hi Toan,
Can you be more clear on the query, that is which comment window?.
From 2017 version, in the model browser user can view the material parameters and its options description in the entity editor.
I think he would like to show informations on screen (or file) output at running the solver.
With SAMCEF solver, we have the command 'ECHO' to do that. I know nothing about RADIOSS.
In such a case user can get the material information in the starter out file. Open the starter out (_0000.out) in Textpad where user can get the material details.
RADIOSS writes these parameters default.
hi,
I know about starter out file. Maybe this kind of information can not be displayed on running window.
Thanks for your quick help anyways
In the solver window it is not possible. In the out file only you can review.
Sorry, I need to be more specific about my question.
When I open starter file of examples in Rdioss, I saw something like picture 1. there were comments above each parameter that make it easier to track material parameter.
But when I created my own a model, tried to make some material also then exported it, I did not have the same like the example (picture 2). there was no comment above each param. So I want to know how can I get the same thing like in the examples.
