Hello everyone,
I am currently working on a project to model and simulate the impact of a motorcyclist against a road barrier to assess injuries, both with and without the use of an airbag.
- Project Context:
- The airbag and motorcyclist models have been fully developed and are functioning correctly in Radioss.
- The barrier model, however, was retrieved from previous work and was initially developed in LS-DYNA. I am now in the process of converting this model to integrate it into Radioss.
- Issue Encountered:
- I used Altair's Convert tool for the conversion. Unfortunately, I noticed that some data, such as the details for bolts, seem to have been lost or misinterpreted during the process.
- My objectives are as follows:
- To determine if there is a method or process that allows the conversion of an LS-DYNA model to Radioss while retaining all information (materials, properties, contacts, etc.).
- To verify that the converted Radioss model is identical to the original LS-DYNA model.
- Specific Cards Requiring Conversion:
- The
*MAT_SPOTWELD_TITLE card used for welds. - The
*INITIAL_AXIAL_FORCE_BEAM card used to initialize axial forces in beams.
I am attaching both versions of the model (LS-DYNA and Radioss) to this message for reference. If anyone has suggestions or experience with this type of conversion, I would greatly appreciate your guidance:
- Is there a way to ensure all data is preserved during the conversion?
- How can I verify that the Radioss model accurately replicates the original LS-DYNA model?
- If necessary, how can I manually recreate or adapt specific cards, such as those mentioned above, in Radioss?
Thank you in advance for your help!
Best regards,
