I imported a custom polyhedral particle into EDEM 2024.1 through a stl file by using the "Import Custom Particle Shape" option. The normal size distribution option for generating the particles gives an option to scale the particles through "Radius".
Can you please confirm if this "Radius" is actually the largest dimension out of length x, y & z of the particle properties that are calculated.
Further, can you please confirm if the "Diameter" used to create the size distribution histogram is indeed the largest or major dimension out of length x, y & z of the particle.
Thanks and regards.
