I have a question about converting 2D faces that I've extracted from 3D elements into a solid. I've tried using the FE Geometry option under Topology to convert the elements, but I'm facing an issue. When I convert each of the three phases (colors) into a solid one by one, parts of the same phase are getting assigned different colors. For example, while converting the green phase, some parts unexpectedly turn red.
Could you please help me with a way to convert each of these phases into solids one by one without this problem?
Thank you!
