despite entering the correct credentials, it keeps saying "invalid credentials" then with multiple tries it, it now showed "account is blocked". How do I solve this?
Sean,
you are not in the rapidminer system. Are you sure you are not on units?
Best,
Martin
Hi, I'm having the same issue. "AI Studio" is rejecting the correct credentials, thus making the application unusable. Is there a workaround here?
