yes Web-APIs or even a stand-alone RTSA would be the way to go. Scheduler is only for heavy duty tasks which take a few minutes or hours.
And yes, Grafana or Pano are using the Web-API endpoints as well.
Cheers,
Martin
Hello, @MartinLiebig Thank you for helping me better understand the difference between endpoints and schedules. I truly appreciate it.
For example, if I wanted to use a defect prediction model in a smart factory to perform real-time predictions through Grafana, this would involve making api calls within the AI Hub. In such a case, would it be better to use an endpoint, or should I consider using a scheduler?
Additionally, if I were to use Grafana or Panopticon, both of which can utilize endpoints, would accessing them via an endpoint be the method Altair recommends? Best, Seulbi
