<?xml version="1.0" encoding="UTF-8"?><process version="10.4.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.4.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.4.001" expanded="true" height="68" name="Retrieve LendingClub Loan Data 2007-2011 (27MB)" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Community Samples/Community Data Sets/Finance and Business/LendingClub Loan Data/LendingClub Loan Data 2007-2011 (27MB)"/> </operator> <operator activated="true" class="concurrency:loop_attributes" compatibility="10.4.001" expanded="true" height="82" name="Loop date_time" width="90" x="246" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="date_time"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="loop_attribute"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="date_to_nominal" compatibility="10.4.001" expanded="true" height="82" name="Date to Nominal" width="90" x="45" y="34"> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <connect from_port="input 1" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve LendingClub Loan Data 2007-2011 (27MB)" from_port="output" to_op="Loop date_time" to_port="input 1"/> <connect from_op="Loop date_time" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
