<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.3.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="Europe/Berlin"/> <parameter key="input_csv_text" value="Att Yahya Jay Tu Magdalena"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="blending:generate_columns" compatibility="10.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="34"> <list key="function_descriptions"> <parameter key="new Att" value="if(length(Att) >= 3, cut(Att, 0, length(Att)-2), Att)"/> </list> <parameter key="keep_all_columns" value="true"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="table input"/> <connect from_op="Generate Attributes" from_port="table output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
