could not initialize HTML5 browser
kimjk3559
Altair Community Member
I searched about this problem and tried many solutions.
But it wasn't resolved. Someone please help me
Here's log
Apr 22, 2024 10:38:10 AM com.rapidminer.tools.I18N setLocale
INFO: Setting locale.
INFO: Using locale en.
Apr 22, 2024 10:38:10 AM com.rapidminer.gui.RapidMinerGUI run
INFO: Launching RapidMiner 10.3.001, platform WIN64, with Java Eclipse Adoptium 11.0.16 on Windows 10 (10.0 / amd64)
Apr 22, 2024 10:38:11 AM com.rapidminer.tools.PlatformUtilities logInfo
INFO: rapidminer.home is 'C:\Program Files\RapidMiner\RapidMiner Studio'.
Apr 22, 2024 10:38:15 AM com.rapidminer.core.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Apr 22, 2024 10:38:15 AM com.rapidminer.io.process.XMLTools hardenDocumentBuilderFactory
WARNING: Could not set http://javax.xml.XMLConstants/property/accessExternalStylesheet for XML processor
Apr 22, 2024 10:38:15 AM com.rapidminer.repository.FileRepositoryProvider load
WARNING: Unknown tag: filesystemRepository
Apr 22, 2024 10:38:15 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category repository registered.
Apr 22, 2024 10:38:15 AM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Cloud Connectivity
INFO: Register plugin: Data Editor
INFO: Register plugin: H2O
INFO: Register plugin: Model Simulator
INFO: Register plugin: Multi Language Pack
INFO: Register plugin: Operator Recommender
INFO: Register plugin: Process Scheduling
INFO: Register plugin: Advanced File Connectors
INFO: Register plugin: Blending
INFO: Register plugin: Browser
INFO: Register plugin: Concurrency
INFO: Register plugin: CTA
INFO: Register plugin: HTML5 Charts
INFO: Register plugin: Interactivity
INFO: Register plugin: JDBC Connectors
INFO: Register plugin: KS Provider
INFO: Register plugin: Legacy Result Access
INFO: Register plugin: Modeling
INFO: Register plugin: Productivity
INFO: Register plugin: Professional
INFO: Register plugin: Remote Repository
INFO: Register plugin: Utility
INFO: Register plugin: Social Media
INFO: Register plugin: Time Series
Apr 22, 2024 10:38:17 AM com.rapidminer.tools.config.ConfigurationManager register
WARNING: Registered configurator Twitter Connection. Please update your extension to use the new connection framework!
Apr 22, 2024 10:38:18 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Init browser setup.
Apr 22, 2024 10:38:18 AM com.rapidminer.tools.config.ConfigurationManager register
WARNING: Registered configurator Amazon S3 Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator Azure Blob Storage Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator Azure Data Lake Storage Gen1 Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator gui.configurable.cloud.azure.gen2.name. Please update your extension to use the new connection framework!
WARNING: Registered configurator Google Cloud Storage Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator Dropbox Connection. Please update your extension to use the new connection framework!
Apr 22, 2024 10:38:18 AM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver net.sourceforge.jtds.jdbc.Driver not found. Probably the driver is not installed.
Apr 22, 2024 10:38:19 AM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
WARNING: Missing database driver class name for Ingres
Apr 22, 2024 10:38:19 AM com.rapidminer.extension.browser.BrowserFactory init
SEVERE: Failed to initialize the Browser, HTML5 components might not be available!
com.teamdev.jxbrowser.engine.ChromiumProcessStartupFailureException: Process exit code: -2147483645
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:294)
at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:163)
at com.rapidminer.extension.browser.BrowserFactory.createEngine(BrowserFactory.java:345)
at com.rapidminer.extension.browser.BrowserFactory.init(BrowserFactory.java:146)
at com.rapidminer.extension.browser.PluginInitBrowser.lambda$initPlugin$2(PluginInitBrowser.java:86)
at java.base/java.lang.Thread.run(Unknown Source)
Apr 22, 2024 10:38:19 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Basic browser setup test starting.
Apr 22, 2024 10:38:21 AM com.rapidminer.extension.browser.BrowserFactory init
at com.rapidminer.extension.browser.BrowserFactory.createBrowser(BrowserFactory.java:253)
at com.rapidminer.extension.browser.PluginInitBrowser.lambda$initPlugin$2(PluginInitBrowser.java:102)
Apr 22, 2024 10:38:21 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
WARNING: Async: Basic browser setup test failed, HTML5 components may not be available!
java.lang.NullPointerException
at com.rapidminer.extension.browser.BrowserFactory.createBrowser(BrowserFactory.java:265)
Apr 22, 2024 10:38:21 AM com.altair.ks_engine.bridge.KSEngineConnectionHandler$1 engineOffline
INFO: KS engine offline
Apr 22, 2024 10:38:21 AM com.altair.ks_engine.bridge.KSEngineSettings initialize
INFO: Initializing KS engine settings
Apr 22, 2024 10:38:21 AM com.altair.ks_engine.bridge.KSEngineConnectionHandler$1 engineStarting
INFO: Starting KS engine
Apr 22, 2024 10:38:21 AM com.rapidminer.repository.RepositoryManager registerExtensionSamples
INFO: Registered 'Time Series' as sample folder.
Apr 22, 2024 10:38:21 AM com.rapidminer.tools.plugin.Plugin initAll
INFO: Extension Professional 10.3.1 was loaded in 7ms.
INFO: Extension Utility 10.3.1 was loaded in 11ms.
INFO: Extension Productivity 10.3.1 was loaded in 15ms.
INFO: Extension Modeling 10.3.1 was loaded in 16ms.
INFO: Extension Operator Recommender 10.3.1 was loaded in 17ms.
INFO: Extension Process Scheduling 10.3.1 was loaded in 18ms.
INFO: Extension Data Editor 10.3.1 was loaded in 20ms.
INFO: Extension Interactivity 10.3.1 was loaded in 24ms.
INFO: Extension Legacy Result Access 10.3.1 was loaded in 26ms.
INFO: Extension CTA 10.3.1 was loaded in 28ms.
INFO: Extension Concurrency 10.3.1 was loaded in 31ms.
INFO: Extension Multi Language Pack 10.3.1 was loaded in 40ms.
INFO: Extension Social Media 10.3.1 was loaded in 52ms.
INFO: Extension KS Provider 10.3.1 was loaded in 78ms.
INFO: Extension Advanced File Connectors 10.3.1 was loaded in 85ms.
INFO: Extension HTML5 Charts 10.3.1 was loaded in 137ms.
INFO: Extension Time Series 10.3.1 was loaded in 201ms.
INFO: Extension Browser 10.3.1 was loaded in 205ms.
INFO: Extension Model Simulator 10.3.1 was loaded in 217ms.
INFO: Extension H2O 10.3.1 was loaded in 319ms.
INFO: Extension Remote Repository 10.3.1 was loaded in 350ms.
INFO: Extension Blending 10.3.1 was loaded in 589ms.
INFO: Extension Cloud Connectivity 10.3.1 was loaded in 1045ms.
INFO: Extension JDBC Connectors 10.3.1 was loaded in 2307ms.
Apr 22, 2024 10:38:21 AM com.altair.ks_engine.bridge.KSEngineInstallationHandler startKSEngine
Apr 22, 2024 10:38:21 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category operator registered.
Apr 22, 2024 10:38:23 AM com.altair.ks_engine.bridge.KSEngineConnectionHandler$1 engineRunning
INFO: Started KS engine
Apr 22, 2024 10:38:23 AM com.altair.ks_engine.bridge.KSEngineConnectionHandler$1 engineDisconnected
INFO: Disconnected from KS engine
Apr 22, 2024 10:38:23 AM com.altair.ks_engine.bridge.KSEngineSocket connectToSocket
WARNING: Cannot connect KS engine socket, socket already set!
Apr 22, 2024 10:38:23 AM com.altair.ks_engine.bridge.KSEngineConnectionHandler$1 engineConnected
INFO: Connected to KS engine
Apr 22, 2024 10:38:23 AM com.altair.ks_engine.bridge.KSEngineConnectionHandler$1 engineReady
INFO: KS engine is ready
Apr 22, 2024 10:38:23 AM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
INFO: No configuration file found for Amazon S3 Connection
INFO: No configuration file found for Azure Blob Storage Connection
INFO: No configuration file found for Azure Data Lake Storage Gen1 Connection
INFO: No configuration file found for gui.configurable.cloud.azure.gen2.name
INFO: No configuration file found for Dropbox Connection
INFO: No configuration file found for Google Cloud Storage Connection
INFO: No configuration file found for Twitter Connection
Apr 22, 2024 10:38:25 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category actions registered.
Apr 22, 2024 10:38:25 AM com.rapidminer.extension.browser.PluginInitBrowser initGui
INFO: Browser was not initialized correctly. Skipping hardware accelerated browser setup test.
Apr 22, 2024 10:38:27 AM com.rapidminer.extension.browser.BrowserFactory init
at com.rapidminer.extension.browser.gui.BrowserPanel.createBrowser(BrowserPanel.java:108)
at com.rapidminer.extension.browser.gui.BrowserPanel.createBrowser(BrowserPanel.java:97)
at com.rapidminer.extension.remote.gui.versioning.VersioningHistoryPanel.createBrowser(VersioningHistoryPanel.java:559)
at com.rapidminer.extension.browser.gui.BrowserPanel.updateBrowser(BrowserPanel.java:138)
at com.rapidminer.extension.remote.gui.versioning.VersioningHistoryPanel.updateBrowser(VersioningHistoryPanel.java:571)
at com.rapidminer.extension.remote.gui.versioning.VersioningHistoryPanel.<init>(VersioningHistoryPanel.java:162)
at com.rapidminer.extension.remote.gui.versioning.VersioningHistoryDockable.<init>(VersioningHistoryDockable.java:38)
at com.rapidminer.extension.remote.PluginInitRemoteRepository.registerRemoteRepositoryDialogs(PluginInitRemoteRepository.java:360)
at com.rapidminer.extension.remote.PluginInitRemoteRepository.initGui(PluginInitRemoteRepository.java:185)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:1662)
at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:1630)
at com.rapidminer.tools.plugin.Plugin.initPluginGuis(Plugin.java:1530)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:489)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:1040)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:972)
at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:333)
Apr 22, 2024 10:38:27 AM com.rapidminer.extension.browser.BrowserFactory createBrowser
INFO: HTML5 safe mode enabled. Creating slower offscreen browser instead of requested hardware accelerated browser.
Apr 22, 2024 10:38:27 AM com.rapidminer.extension.remote.gui.versioning.VersioningHistoryPanel updateBrowser
SEVERE: Failed to create browser to display Snapshot History panel
Apr 22, 2024 10:38:27 AM com.rapidminer.io.process.XMLTools hardenDocumentBuilderFactory
Apr 22, 2024 10:38:29 AM com.rapidminer.extension.remote.PluginInitRemoteRepository$2 run
INFO: Community repository 'Community Samples' added.
INFO: Community repository 'Training Resources' added.
Apr 22, 2024 10:38:30 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category academy registered.
Apr 22, 2024 10:38:30 AM com.rapidminer.gui.search.GlobalSearchGUIRegistry registerSearchVisualizationProvider
INFO: Global Search GUI provider added for category academy.
Apr 22, 2024 10:38:35 AM com.rapidminer.gui.MainFrame finishInitialization
WARNING: Not adding legacy connections menu even though legacy configurables are present. Check log for offending extensions
Apr 22, 2024 10:38:40 AM com.rapidminer.extension.cta.tools.CallToActionScheduler checkRules
WARNING: No visualization available for CTA rule 'NPS-GMQ-FEEDBACK-01_query_fcpt'.
Apr 22, 2024 10:38:47 AM com.rapidminer.gui.search.GlobalSearchGUIRegistry registerSearchVisualizationProvider
INFO: Global Search GUI provider added for category operator.
INFO: Global Search GUI provider added for category repository.
INFO: Global Search GUI provider added for category actions.
Apr 22, 2024 10:38:47 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category marketplace registered.
INFO: Global Search GUI provider added for category marketplace.
Apr 22, 2024 10:39:35 AM com.rapidminer.extension.browser.BrowserFactory init
at com.rapidminer.extension.browser.BrowserFactory.createBrowser(BrowserFactory.java:217)
at com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI.createChartSceneJxBrowser(HTML5HighChartsChartGUI.java:436)
at com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI$1.doInBackground(HTML5HighChartsChartGUI.java:168)
at com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI$1.doInBackground(HTML5HighChartsChartGUI.java:164)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Apr 22, 2024 10:39:35 AM com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI$1 done
SEVERE: Failed to create HTML5 browser!
And I attach log file. Please help, tks
Hi kimjk,
thank you for the report.
- Is this a new issue?
- Is there anything special about the system, like a non-ascii username, or unususal graphics card?
Have you already tried to delete the%HOMEPATH%/.RapidMiner/internal cache
folder (while RapidMiner Studio is not running)?
If this doesn't help, have you tried to enable the HTML5 Safe Mode?
Greetings,
Jonas1 -
Hi jwpfau,thank you for your replyWindows 10's username is English, and it uses an ordinary geforce graphics card.I also tried deleting all caches, but the result was the same.I tried both HTML5 Safe Mode and Legacy mode options, but the results were the same.One strange thing is that when running RapidMiner, the Chromium process was not found on the PC.In the case of a friend's PC with normal visualization functions, I could see Chromium running together when RapidMiner was run.Could this be related?Please help, thank you0
This is a curious one. If you search for the error code of Chromium (-2147483645) on Google, you will find the same error across other products that use Chromium engines (like tools using Electron, QtWebEngine, etc) - but no real solution.
It seems (and I use that word very loosely here) to be related to certain security settings of the machine in question, but I did not find anything concrete on short notice.
My best advice I can currently give you is to upgrade to the next version of Studio coming out very soon, and see if that works. In it, we upgraded the embedded Chromium to one of the latest versions, and my hope is that this fixes the issue.
Marco0
