<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.3.001" expanded="true" height="68" name="Create ExampleSet" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="5"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Country Germany Croatia Belgium"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="retrieve" compatibility="10.3.001" expanded="true" height="68" name="Retrieve" origin="GENERATED_TUTORIAL" width="90" x="45" y="187"> <description align="center" color="transparent" colored="false" width="126">IMPORTANT: you will need to provide your API key as a Dictionary Connection to make this work. Provide this connection as the second input.</description> </operator> <operator activated="true" class="generative_models:send_prompt_openai" compatibility="2.0.000" expanded="true" height="82" name="Get GDP" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="model" value="gpt-3.5-turbo"/> <parameter key="name" value="GDP"/> <parameter key="prompt" value="What is the GDP of [[Country]]? Just the answer, no prose."/> <parameter key="max_target_tokens" value="256"/> <parameter key="temperature" value="1.0"/> <parameter key="top_p" value="1.0"/> <parameter key="frequency_penalty" value="0.0"/> <parameter key="presence_penalty" value="0.0"/> <parameter key="conda_environment" value="rm_genai"/> <description align="center" color="transparent" colored="false" width="126">The result of this operator will be a data set enriched with the results of the prompts sent to OpenAI.</description> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Get GDP" to_port="data"/> <connect from_op="Retrieve" from_port="output" to_op="Get GDP" to_port="connection"/> <connect from_op="Get GDP" from_port="data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
